Subject: How do i change the global font of the site
balousta
03 Sep 2008 3:41 PM
How do i change the global font of the skin of my web site?
regards
03 Sep 2008 7:55 PM
The font definitions for a site generally should be defined in skin.css. If you haven't seen them already, I'd recommend that you review the skinning tutorials available here.
04 Sep 2008 4:27 AM
If you are new to skinning we recommend you start with Issue no 5 and 6 and then follow the tutorials through in issue number order.
To quickly answer your question, you will probably need to check the font styling for the
body
and
.Normal classes - the normal class is used by the text / HTML module
balousta
04 Sep 2008 2:31 PM
Thank you for your advice, I have seen the  tutorials long time ago, but I'm not good in css in general. I will apply the change to Body and Normal classes as per the advice.
thanx
Forums > Users Lounge > Everything Else > How do i change the global font of the site
