Subject: Run ASP Script in DNN
esgrossman
01 Sep 2008 4:40 PM
I have a form written in old fashioned ASP. The first script is a form, which then goes to a script to process the inputs from the first form.
I can run the first script from a host that supports ASP using the Iframe module. How and where should I run the second form? From another page using Iframe? From the server hosting the ASP script? Or, from the DNN host, which will process ASP script?
Thanks ...
02 Sep 2008 7:48 PM
Why not just try converting your existing scripts to run in DNN?
If you look at the page source of the pages, ASP.NET has already converted them into HTLM and (probably) some javascript. I might start by taking that code and pasting it into the source view of an HTML module.
You'll have to do this, too, with the page that gets the result of the first form. That might be somewhat harder, but it might work ...
esgrossman
02 Sep 2008 7:59 PM
I solved the problem by running the first ASP as an Iframe referencing a server that runs old ASP. I then had each script redirected to the next ASP script on that Server. They all used the same DNN page Iframe module.
Unfortunately, I do not know ASP.NET and do not want to take the time to convert the code.
Thanks for your response.
02 Sep 2008 8:00 PM
That will certainly work.
Forums > Users Lounge > Everything Else > Run ASP Script in DNN
