Good Morning Mate!
Well, tock a nice lazy break over the weekend, but with a bit of work.
I brought the Note-Book along and looked through Issue 26 – 28 of your tutorials. Probably going to save you guys 1000-plus questions.
But here’s a couple anyway: Regarding the Curiously _ Green Skin.
You recommend I have one H1 Container and the H2 Containers in the content pane.
And the H3 Container in the Left Pane?
This must mean that I have to specify containers individually in the Module settings???
I also installed the template before I created this Portal, and got this error:
“Curiously_green.template is not a valid Portal Template File.”
Seems like I misunderstood your instructions from last week Lee? (Below)
Cheers..
Olle...
You need to use the correct container for the content panes, otherwise the text will not display correctly in the bittersweet skin.
I would suggest you install the template that comes with the bittersweet skin so you can see how the content can be added to the page.
I would recommend you install the skin using the host menu upload the template files create a new portal, and while creating the portal select the new template |
