Subject: Installing DNN on XP Pro video
DavidWSnow
23 Aug 2008 10:53 AM
After a year and 3 disk corruptions with Vista I am in the process of "Upgrading back to Windows XP Pro."  In the future I may make a post on the details of why later.
Needless to say during that year I did many DNN install on Vista and had forgotten the differences in installing on XP Pro.  I went back to your video and several of the got-yah's were covered.
Two comments:
  • Please try to have the Issue number on all descriptions of what is covered. I giigle searched and got a page on your sit with no issue number only a date. I them had to click thru issue by issue to get to the right on, so that I could view the right saved copy on my system.
  • In the video you recommended the "Advanced" SQL Server 2005 kit. Yet again I descoved that I, and maybe others, really need the "Toolkit" version. I need this because it contains the DTS tools that allow a user to transfer data from excel, access, flat files, etc. to SQL Server 2005. I rely on the DTS wizard to do this to update some data on my application.  BTW other might find this a useful tool.
However, dispite these minor problems, DNN Creative saved my but and a lot of time again.
DaveS
27 Aug 2008 3:04 AM
Hi Dave,
All tutorials show which issue they came from. If you go to the main tutorial page and in the beginners section you will see:
How to install DotNetNuke 4.5 to Windows XP Pro with IIS
on that page you will see the issue number for the tutorial below the image.
Forums > Users Lounge > Everything Else > Installing DNN on XP Pro video
