Subject: CSS Rounded cornet container
cozahost
13 Aug 2008 8:37 AM
Hi there
I am trying to create a container with rounded corners without using images.  I discovered the Nifty Corners article, and found that it works well with pure HTML files.
You will find the article, here: http://html.it/articoli/esempi/articoli_pro/nifty/index.html
However, when I implement the same principles in a DNN container, it only works after you refresh the page (using IE7).
I attached a very simple version of the container to this post, does anybody have any advice or know of any IE7 bugs/reason for the problem - even better how to fix?
The same container works 100% when viewed with Firefox.
Regards
Wadda
Attachment: 1813375846071.zip
Forums > Users Lounge > Everything Else > CSS Rounded cornet container
