Subject: Upgrading from 04.05 to 04.08
ollep
12 Aug 2008 4:59 AM
Hi Guys…
I’ve been away from the admin side of the DNN sites for a while.
I now found that I running DNN 04.05.00 on most site, while the current version is 04.08.04.
Are there any issues upgrading a few steps right away – or it’s just to go ahead?
(I have the experience of messing up with previous upgrades.)
THANXXX
ollep
13 Aug 2008 6:41 AM
I can't remember what version I upgraded from when I went to 4.8.4, I think some people have upgraded to 4.6.x and then 4.8.x - but, I would simply download a backup of your live website install it to your localhost installation and then try to upgrade straight to 4.8.4, in theory it should work just fine.
Make sure you create a full backup of your website!
13 Aug 2008 8:28 AM
I think that it still is a good idea to go to 4.6.2. Once you have done that, upgrades do not require any manual editing of the web.config file.
Forums > Users Lounge > Everything Else > Upgrading from 04.05 to 04.08
