Subject: Restricting user/admin access to Page Functions
omorgan
15 Jul 2008 9:42 AM
Howdy,
I have a question about the "Page Functions" feature of the administrative control panel. Is it possible for me to deny permissions to the Add Page, Delete Page, and Copy page? I know that I can grant permission specifically to each module but I would like for my users to be able to add and remove modules but not add or delete pages. If this is covered in a tutorial please let me know which one and I'll review that.
Owen - http://www.fdwsnetworks.com
17 Jul 2008 9:51 AM
I have not come across a technique for doing this, thanks,
17 Jul 2008 7:18 PM
The Cambrian version of DotNetNuke will feature additional ways to grant access to administrative functions. This might be one of them. If so, it's probably less than a few months away ...
Forums > Users Lounge > Everything Else > Restricting user/admin access to Page Functions
