Subject: File Manager with Limited Access
tds_softwaredev
03 Jul 2008 5:02 PM
Hi Everyone,
I was hoping someone might have a solution for a little problem I have run into. I want to give some people access to the file manager to upload files to a DNN site. I followed the tutorial "How to limit access to the admin menu" to move the file manager out of the admin menu and into a new "Site Admin" menu. I am able to do just about everything, I can move files around create new folders and delete folders.
What I cannot do is add new files. I click upload and instead of the page refreshing and getting the upload module box I get an "Access Denied - Either you are not currently logged in, or you do not have access to this content."
I am still able to use the File Manager with the host and admin accounts and any accounts I give Admin access to. I'm guessing that for some reason the permissions are being lost between the file manager and the upload. I checked the File Manager security settings on the folder and I gave read/write access. I don't know what else to do. Does anyone have any ideas please?
Thanks everyone for taking some time to help.
04 Jul 2008 7:27 AM
I have just tested this and have the same problem. Perhaps it would be worth looking for document upload management modules? there was a discussion here
You may want to look at bring2mind Document Exchange
tds_softwaredev
07 Jul 2008 10:18 AM
Thanks for the help Lee!
tds_softwaredev
07 Jul 2008 1:23 PM
Hey Lee,
     If you ever run into this again I found a solution. The file manager webupload.ascx.vb file has a method CheckSecurity() that has a hard coded check to see if the person trying to access it is either the admin or super user. If it's not one of those access is denied. All I had to do was add an extra if statement saying if the user is in my "site admin" role to allow access.
     If anyone is interested the code is:
If DotNetNuke.Security.PortalSecurity.IsInRole("YourRoleName") Then
     DenyAccess = false
End If
Thanks a bunch for your help and for pointing me in the right direction!
10 Jul 2008 1:41 PM
That's great, thanks for the tip I'm sure everyone will find that useful,
Forums > Users Lounge > Everything Else > File Manager with Limited Access
RE: Database error by derpir
