Subject: annoucement module
rizwan7705
17 Jun 2008 6:51 PM
hello is it possiable that i can limt the acces for annoucement module. basicly what i m trying to do that few user shud be able to put annoucemnt. they shud not be able to change the basic setting. can i do in dnn annoucemnet module or if not then plz tell me if there is any module which i can buy for this.
thanks
18 Jun 2008 8:13 AM
Yes this is possible, you will need to:
Create a new security role - eg. 'announcement access'
for each user that you wish to give access to the announcements module, apply the new security role to their user account
on the announcements module, go to the module settings, for the 'announcement access' security role tick edit permissions.
This will give those users access to add new announcements, but they will not be able to get to the admin functions of the module.
for further information on user accounts, security roles, etc. Have a look at:
I mentioned the ventrian subscription to you in a previous post for the subscription tools module, if you get a subscription from ventrian, then it is worth looking at their News Articles module as it provides a lot more functionality than the announcements module.
rizwan7705
18 Jun 2008 6:00 PM
thanks for help i really say this from core of my heart.basilcy i m making web site and it is a big very big
i m new and this is my first site so i m facing these problem.oh one question jus came in my mind. is there anyway i can use nested security role in dnn ?bcoz i didnt find any thing even if u configer active directory.help again plz
again thanks alot
reason i m asking nested security role bcoz there gona be 1000s of security role
19 Jun 2008 4:30 AM
You can set up DotNetNuke role groups which may help you out, for further information have a look at this tutorial:
DotNetNuke Security Roles new features
rizwan7705
24 Jun 2008 5:56 AM
thanks for help lee. i wana know is there any link where i can download document about dnn core madules help or information i need support document for all madule which comes with dnn instaltion
plz help me out thank
24 Jun 2008 8:10 AM
For help with core modules, see my answer in your other thread.
Forums > Users Lounge > Everything Else > annoucement module
Glad you sorted it, thanks,
