Subject: multi-language
Absinte
15 Jun 2008 9:45 AM
I suppose this question has been made before on these forums, but I couldn't find it.  I need to make a site in 3 languages. Someone told me that I need a localizer, a hack and a couple of modules. But I don't know how to do this.
15 Jun 2008 10:53 AM
DotNetNuke's "static" language is localized. There are language packs available for many languages.
You greater problem is localizing the content. There are some modules that support multiple languages. If you look at places like Snowcovered you'll find them. Or Google them.
I can't give a recommendations because I haven't used any of these modules. If you do use one, please let us know how it works for you.
Absinte
15 Jun 2008 4:37 PM
Thanks Joe. But I'm not sure if I explained myself properly. I'm not interested in translation of the contents. I can do that myself. What I don't know is how to create the 3 versions of the site, one for each language, that will open according to the language of the visitor's browser, or that they can switch to by clicking on those typical flag-links.
15 Jun 2008 8:31 PM
As I undertand things, the multilanguage modues don't translate. Instead the they allow you to insert multiple versions of content in different languages, and the display is based on the user's language choice.
