Subject: paypal problem
rizwan7705
13 Jun 2008 4:41 AM
in site setting i have configered my paypal account. i have made 3 security role and in that i have  set amount and duration for one month but i didnt do anything in trial section but when u got to manage services but security roles r showing with free trail option but i dont set that help me plz in that.
16 Jun 2008 3:42 PM
I don't know if it has been fixed yet, but last time I check it, the trial section showed up and if a user clicked on it, it gave them completely free access!
I would suggest you use a module such as ventrians subscription tools
rizwan7705
17 Jun 2008 6:27 PM
thanks lee i m really happy for that help.is it possiable that if i use that tool which u told me for paypal. and i use rsvp code system which is in dotnetnuke at the same time?
18 Jun 2008 1:53 AM
Yes the module is completely separate, so you should have no problems using RSVP as well, thanks,
18 Jun 2008 12:49 PM
Also note that the new version of DataSprings Dynamic Registration supports PayPal integration.
rizwan7705
18 Jun 2008 5:48 PM
the new one is 3.2 is that's then one r u talking about
19 Jun 2008 4:24 AM
yes dynamic registration 3.2
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
