Subject: subscribing with code
rizwan7705
08 Jun 2008 7:43 AM
hello
i m making a state agaent website where owner can but there house for rent.and there are more featurs.basicly what i m trying to do now that
when tannet is going to subscribe some thing he or she need permission from the owner. so is it possiable can i use RSVP code.
i mean if i configer role with RSVP code and they ll ask that code from owner and when they put that code in they ll access to the link and which ll take to subscribtion. i m jus thinking by doing this is that gona by pass the subscribtion role
plz help me out
and which free module can i use so where use can upload and download their files
plz help me in it
thanks
Forums > Users Lounge > Everything Else > subscribing with code
