Subject: Is there a more advanced UDT module?
dmcniel31
05 Jun 2008 8:55 PM
I need a module like the UDT but with one key feature that I don't believe the UDT module has.  I need to total the integers in a column and have that number in a footer under the column.
I have Xmod but it's list grid doesn't have this ability.
Any suggestions?
Dan
05 Jun 2008 10:10 PM
Have you asked Sebastian Leupold about this possibility?
Forums > Users Lounge > Everything Else > Is there a more advanced UDT module?
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
