Subject: creating email and securty role
rizwan7705
24 May 2008 8:43 AM
my first question is that how many securty role dose dnn supports ?bcoz what v r desinging it could go up too 1000s and 1000s securty role.
my 2th question is
 our web site is going to be urooj.co.uk and v r  doing this all in dnn my question is that .is it possiable that i can create email adress like rizwan@urooj.co.uk  in dnn. i mean u r creating emails in dnn. i know u can setup  like which role can send email but i want to know creating email .
thanks for all those ppl who helped me b4 and i asking for their help again
24 May 2008 9:58 AM
Yes, DotNetNuke can use an unlimited number of security roles. You'll have to manage them, though. But I'm wondering why you might need so many. Perhaps there is a better way.
As for email, I'm not aware of a module that creates email accounts. DotNetNuke does not include an email server.
Forums > Users Lounge > Everything Else > creating email and securty role
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
