Subject: control panel keeping rolling up
rizwan7705
19 May 2008 9:25 PM
i have installed dnn 4.8.2 on w/host.
the problem is i see rolled up control panel and when i click to pull down the control panel
comes down but as page loads up completly. the control panel rolls up automaticly. i m having same problem in other features too like if i click to other option i mean plus sign they come down and go up again i m worried  please
help me i cant add pages and madules or nothing plz help me in it lee thanks
thanks
19 May 2008 11:09 PM
I haven't heard of that before. I'd check to make sure that AJAX and Java are installed correctly. Does this happen on multiple computers?
rizwan7705
20 May 2008 5:55 PM
how would i check ajax and java installed correctly?and yes it is happening on every computer i tried 3 so for plz help me in this
20 May 2008 8:41 PM
Hmmm ... this is an odd one. Can you perhaps make a second DotNetNuke installation and see if it happens there as well.
rizwan7705
21 May 2008 4:12 AM
thanks for trying to help me out but problem was with windows internet explorer 7.when i tryed firfox it is working fine.i guess microsoft shud learn how to develop explorer.
21 May 2008 7:24 AM
Well ... I haven't seen this problem in IE, so your job might not be over ...
Forums > Users Lounge > Everything Else > control panel keeping rolling up
Hello,DNN Nav is available with the default install of DotNetNuke and already installed. - Just look...
RE: Congratulations to Lee and the DNN community! by leesykes
Hello,Glad to hear it is useful. I didn't go for the DVD, but went for the net effect magazine, rece...
RE: Register and Login Links by jncraig
The general scheme is that CSS styles are attached to skins.  I believe that it's possible to switc...
RE: User Import from Excel by jncraig
I have used John Mitchell's script (http://blogs.snapsis.com/PermaLink,guid,c9d3082b-d7b1-4dfb-8c9c-...
User Import from Excel by sstoos
I'm working on a website that the client has several 100 members that they want to add as users.  Is...
RE: Menu bar and CSS by wsiwpg
Ok, i have now added some sub pages to the site. Can you please go look at it now.Thanks.
RE: DNN Creative News Feed not Working? by mgordon
In my humble opinion, the latest News Feed Module (version 4.00) is a complete piece of crap.  It ha...
RE: Register and Login Links by Faith
Joe: Two short questions. 1) It is possible to set a css style sheet for a determined user? ...
Hello, Below is a few paragraphs outlining some background, but my question is: Can I take a p...
RE: DNN Creative News Feed not Working? by ollep
  One last bit before bedtime.   With the below section in the “.xsl” I managed to get it down to...
RE: DotNetNuke UK User Group Meeting by leesykes
This meeting is now cancelled due to insufficient numbers, we will try again in the new year
  Hi Again.   Seems like the “News Feed Style Sheet” option is changed to “XSL Transformation? A...
Hi Again.   Now I’m on to the News Feed Module and RSS Feed.   Is the News Feeds 04.00.00 quite ...
RE: Query regarding menu by jncraig
Doing that forces a reload and recompile of your site.
RE: Query regarding menu by ImageSmith
I have had this problem before. A quick fix: retouch the web.config file by opening in notepad, make...
RE: Trying Flash again - in Firefox. by jncraig
Here is how we have done it ... Note that I put in a bunch of spaces to break the tags, so you'll ...
RE: Changing the House Menu?? by ollep
Thanks lee. The configuration for the separate sub-menu-item list, do you show that in a tutorial...
Trying Flash again - in Firefox. by ollep
I still looking for ways of running Flash Movies in Firefox??? The code provided in the DNN Creat...
Thanks Joe! Just tested and it works fine.   Only thing was that I could only save in the portal ...
Congratulations to Lee and the DNN community! by ollep
On Lee’s recommendation I ordered the “Stompernet DVD” and the first issue of “Net Effect” – and che...
