Subject: Moving installation from one domain to another
owensammut
06 May 2008 10:29 AM
hi there,
im trying to move an installation from one domain to another. (old - www.bma.com.mt/dotnet)(new - http://www.boatsandyachting.com/dotnet)
ive done this with a simple ftp transfer.
ive also added a Portal Aliases with the new location and restarted the application.
for some reason im still getting re directed to the old installation.
Ive made no changes to the sql db or the web.config as the database will remain on the same server.
Please help as ive read through a ton of forum posts and articles and cant find any solution to this
thanks
Owen
06 May 2008 7:15 PM
Even though you're moving only the web server, be sure to carefully read over
The redirection is coming from the portalalias table.  So, you must remove the old entries in addition to adding the new ones.
Forums > Users Lounge > Everything Else > Moving installation from one domain to another
