Subject: Creating a Module
lilryno
01 May 2008 10:11 PM
Does anybody have any good tips on templates used for creating DNN4.8 modules in Visual Studio 2005?  I used to code in VS2003 using Vic Masana's templates and that worked great.  I've just recently upgraded to VS2005 and am wondering how to get all setup to start coding modules again.
I've also heard there is a new way of packaging Private Assemblies now?  Is there a video or tutorial that would help me out?
01 May 2008 10:20 PM
I'd recommend spending some time at Mitchel Sellers' site, especially his blob. The site is mitchelsellers.com.
lilryno
22 May 2008 7:40 PM
I'd like to see a tutorial specifically made for VS2005 and creating modules in both WAP and WSP formats. I would really like that. Using SQL 2005 would be even better.
Any chance of seeing this?
22 May 2008 11:11 PM
Keep an eye out on Chris Hammond's blog (chrishammond.com) or on the Engage Software website (engagemodules.com). Chris spoke at our local DotNetNuke User's Group last night and one of the things that he showed off was a template for module building. He promises to make a version available in the next week or two.
The template is specifically for WAP development. I believe that Chris' blog has other posts about module development.
Also, you should spend lots of time at Michael Washington's adefwebserver.com site.
Forums > Users Lounge > Everything Else > Creating a Module
RE: Pop up window by jncraig
Pop up window by yerann
