Subject: PayPal Buy Now buttons in DotnetNuke Portal
trevorclare
01 Feb 2008 2:59 PM
I recently tried to add a PayPal Button and found it will not work in DotNet Nuke. There are add-on modules available for PayPal but this tip from John Mitchell's Blog will do the trick.
http://blogs.snapsis.com:80/PermaLink,guid,94277650-bd4c-445f-badf-b84646ecc8eb.aspx
Forums > DotNetNuke® > Quick Tips > PayPal Buy Now buttons in DotnetNuke Portal
ok great, glad to help,
