Subject: Database + SQL Strugglers
eureka
13 May 2006 5:38 AM
I have recenlty found a  tool which has helped me in my struggle with MSSQL, it makes SQL more user friendly.
It has been a great help, in as much as I can create, view, edit, tables etc.,  on my desktop which are located on a remote server.
http://www.aquafold.com/index.html
Lynn
Forums > DotNetNuke® > Quick Tips > Database + SQL Strugglers
