Subject: Can I fix the Menu Navigation Width?
justinspray
25 Oct 2007 12:59 PM
I have a main Navigation Menu that is too long, and it sttretching the whole skin.
Can I set a Max. Width in the CSS?
Cheers,
Justin
Nuke Master I
Nuke Master I
25 Oct 2007 7:59 PM
Menus are quite configurable. Which menu are you using, and which DotNetNuke version?
Also, consider that your "main" menu should have just a few entries for usability. If it's getting too wide, you might want to reconsider your site's organization. Can some of those "main" topics be made secondary topics?
Forums > DotNetNuke® > Quick Tips > Can I fix the Menu Navigation Width?
Login page by shanny234
---resolved---
03.04.00 Thanks Bryan
