Subject: problem with Adding module
john20
25 Oct 2007 9:08 AM
Hi Experts,
I creating module using visual basic.net now i m adding user control in that and in code window i like to add
following code but it is giving me error like 'Type expected' . i have added refrence of dotnetbuke in that module.
when i m inheriting the portalModulecontrol it is giving error.
can u please tell me what i need to do .
Imports DotNetNuke
Public Class ViewRandomText
  Inherits DotNetNuke.PortalModuleControl
-john
26 Oct 2007 10:14 AM
are you adding that reference inside of the module? If this is a class inside of the module, you don't need to reference DotNetNuke.
Forums > DotNetNuke® > Quick Tips > problem with Adding module
