Subject: Having permissions problems with DNN? Try this...
andyhock
09 Jul 2007 1:10 PM
Since so many of us have had these problems in the past, I thought I'd post a helpfule .aspx file that you can run *in the root folder* of your website, to see what the 'identity' of the user needed to run in that folder (and the subfolders).
Copy the code below, and save it into a 'permissions.aspx' file, in the root folder of your website.
So, if your website is at http://localhost/dotnetnuke_2/, and the physical directory for this root folder is C:\websites\dotnetnuke_2\website\, then copy the permissions.aspx file to the C:\...yada folder abvoe, open your browser, and type:
http://localhost/dotnetnuke_2/permissions.aspx
It should display the identity permission needed that is missing to run a webpage in that folder.  You may have to run it more than once.  I can improve this script as I get feedback from it...so let me know how it works out...
Here's the script to copy and save in the permissions.aspx file:
<%@ Page Language="VB" %>
<%@ Import NameSpace = System.Security.Principal %>
<script runat="server">
  Sub Page_Load()
    Dim stmp As String = WindowsIdentity.GetCurrent.Name()
    LabelPermissions.Text = stmp
  End Sub
</script>
  <form> id="form1" runat="server">
      Label
  </form>
DotNetNuke and .NET web parts, web services, modules and code snippets.
Nuke Master I
Nuke Master I
09 Jul 2007 6:41 PM
Thank you for this contribution!
10 Jul 2007 9:31 AM
Hi Andy,
I've moved this into the quick tips section, thanks,
Lee
thanig
29 Sep 2007 8:23 PM
I'm getting the error:
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: BC30451: Name 'LabelPermissions' is not declared.
Source Error:
<PRE>Line 6:      Dim stmp As String = WindowsIdentity.GetCurrent.Name()
Line 7:
<FONT color=red>Line 8:      LabelPermissions.Text = stmp
</FONT>Line 9:    End Sub
Line 10: </script> </PRE>
Source File: E:\Inetpub\vhosts\stmarysbellevue.com\httpdocs\site\permissions.aspx    Line: 8
what am I doing wrong?
andyhock
19 Jan 2008 10:55 AM
Sorry I took so long to respond. I hadn't visited in a while...
I believe the reason you are receiving this error is because you do not have the IIS setting for 'compile ASP pages' set.
Open up IIS. Right click on your default web site. Select Properties. Go to the Home Directory tab. Click 'Enable Parent Paths' checkbox. Also make sure your default language is VBScript. You might also want to enable ASP Script Debugging in the 'Debugging' tab.
Now, I'm not *positive* about this, but I think it will fix the issue...it's definitely something to do w/your settings for ASP...
Hope this helps!
Forums > DotNetNuke® > Quick Tips > Having permissions problems with DNN? Try this...
RE: style search CSS or XML by mmcinulty
Hi Leei was able to replicate the mouse over affect by using the css, the problem is that i still ha...
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
