Subject: Uploading a Skin FAQ
10 Oct 2005 3:19 AM
When I try to upload a new skin, I go to admin, skin, and click on the module drop down box. But there is no option for uploading skins. How do I upload a skin?
You need to enable the permissions for the individual portal to upload skins, you do this by:
Login as HOST Go to Host >> Host Settings
Under Advanced >> Other Settings is Skin Upload Permission which is by default set to Host.
Change to Portal.
Forums > DotNetNuke® > Quick Tips > Uploading a Skin FAQ
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
