Subject: 4.5.2 New Search Web Option Disable
harlowj
02 Jun 2007 7:47 PM
If you were like me, you were suprised to see your skin change when the 4.5.2 upgrade came out with a new "web" and "site" search option.
You can remove these options by putting the following code in your skin file for your search box.
The Search SKO has 3 new attributes:
   Attribute Values Default Description
• ShowSite True, False True display/hide option "Site" to perform a search of the current site (DNN portal)
• ShowWeb True, False True display/hide option "Web" to perform a search of the WWW using the search site, as set up in Site Settings (Google, Yahoo, MSN)
• UseWebForSite True, False False use the WWW search Site, as set up in Site Settings,  to perform searches of the current site (DNN portal). Note: this uses the search index stored at the the search site; any non-public content will not be included!
I found this hidden on DNN site here: http://www.dotnetnuke.com/Community/Blogs/tabid/825/EntryID/1443/Default.aspx
thanks
jh
05 Jun 2007 6:00 AM
Thanks, that's useful,
Forums > DotNetNuke® > Quick Tips > 4.5.2 New Search Web Option Disable
RE: Database error by derpir
