Subject: Using DotNetNuke Newsletter Module Without Admin Rights
28 Sep 2005 2:16 AM
This tip tells you how to allow end-users the ability to use the DotNetNuke Bulk-Email functionality without giving them full admin access to the site.
You can view this tip by Brian Orrell here: http://blogs.parivedasolutions.com/borrell/archive/2005/09/25/DNNBulkEmail.aspx
Forums > DotNetNuke® > Quick Tips > Using DotNetNuke Newsletter Module Without Admin Rights
