Subject: Give your child portal a full domain name
eureka
07 Jan 2007 6:28 AM
I came across this tutorial :Give your child portal a full domain name
http://duhnetnuke3.net/DNN3PortalSetup/AddanHTTPAlias/tabid/110/Default.aspx
Regards
Lynn
Forums > DotNetNuke® > Quick Tips > Give your child portal a full domain name
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
