Subject: Typetester - Compare fonts for the screen
17 Jan 2006 4:02 AM
This is a useful utility where you can experiment with different fonts, settings and colours to find the most appropriate for your website design.
You can try this here: Typetester
23 Jan 2006 9:02 AM
This is also a useful tool for testing the visibility of text on a background with various colours:
http://www.colorcombo.com/bgtxt.html
Forums > DotNetNuke® > Quick Tips > Typetester - Compare fonts for the screen
