Subject: Free database administration tools
eureka
24 Jul 2008 6:10 PM
Hello
Aqua data studio is a free database tool, which sits on your desktop and allows you to access  your on line database.  You can browse, create, edit, and execute SQL scripts and much more.
http://www.aquafold.com/
Lynn
24 Jul 2008 6:24 PM
Thanks, Lynn.
And, for those who might not be aware, Microsoft's SQL Server Management Studio Express version is also free.
Forums > DotNetNuke® > Quick Tips > Free database administration tools
