Subject: Free Website Grader SEO Tool
eureka
23 Jul 2008 7:59 AM
Hello
I came across this useful Free SEO tool, it is a Website Grader that measures the marketing effectiveness of a website. It provides a score that incorporates things like website traffic, SEO, social popularity and other technical factors. It  will also provide a competitive analysis for websites of your competitor.
http://www.websitegrader.com/
Lynn
Forums > DotNetNuke® > Quick Tips > Free Website Grader SEO Tool
