Subject: Skins Tokens not working
billbayjr
14 May 2008 2:53 PM
I'm following the convert XHTML template to DNN skin tutorial... and the skin tokens are not being recognized after my skin is installed in DNN 4.8.1 ... shows at text (i.e. [LOGIN])
I included the skin.xml and the doctype.xml files in the zip package.
I'm sure there is something simple I missed.
17 May 2008 8:15 PM
Did you include a proper manifest file? Are the objects referenced in the skin file?
19 May 2008 7:44 AM
perhaps it is the location of the files in the zip file? - You can attach the skin to this forum post for us to look at if you wish, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > Skins Tokens not working
Backup Live Website without control panel? by ollep
We are hosting with Re-Invent.com, a DNN host that doesn’t allow Control Panel access. We are ther...
Hi Slowly sorting it out. www.goldcoastwebwiz.com/dotnetnuke/q1 The logo position is OK. B...
Glad you sorted it, thanks,
