Subject: Looking for website design inspiration?
13 Dec 2005 4:51 AM
Here's an interesting website to check out:
http://www.dark-i.com
It a showcase for website design. You can submit your own website for review.
- A good source of inspiration for your own web designs.
23 Jan 2006 4:16 AM
This link provides a directory of websites that have been created with DotNetNuke:
http://www.faktnet.com/DotNetNuke/DotNetNukeWebsitesDirectory/tabid/140/Default.aspx
Forums > DotNetNuke® > Quick Tips > Looking for website design inspiration?
