Subject: Site initial load size - optimization
18 Apr 2008 3:49 AM
by andyb1979
I found a site that allows you to see what's the initial load time of your site on various internet connections. In particular, it analyses the effect of images, HTTP requests, css/js/html. Here's the link:
http://www.websiteoptimization.com/
Forums > DotNetNuke® > Quick Tips > Site initial load size - optimization
Member log in by HUGHD37IUOE
Video Problem by icdlbake
