Subject: DotNetNuke 5.3.0 Released
17 Mar 2010 10:00 AM
Joe Brinkman's blog has all of the details.  But, I found this interesting:
New Features
  • Templated User Profiles - User profile pages are now publicly viewable
  • Photo field in User Profile - Users can upload a photo to their profile
  • User Messaging - Users can send direct messages to other system users
  • Search Engine Sitemap Provider - The sitemap now allows module admins to plugin sitemap logic for individual modules.
  • Taxonomy Manager - Administrators can create hierarchical category lists that can be shared and used across modules
17 Mar 2010 10:06 AM
very interesting!
18 Mar 2010 3:46 PM
Whoops! From Joe Brinkman: "With any software product you will occasionally have a release that you wish you could take back. Microsoft had Windows Vista, and Tuesday we had DotNetNuke 5.3.0." Version 5.3.1 is due next week. More details are in Brinkman's blog.
Forums > Users Lounge > Announcements > DotNetNuke 5.3.0 Released
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
DNN Creative Subscribe
