Subject: FREE DNN Power Login module
codingstaff
07 Dec 2009 4:10 AM
Coding Staff is proud to announce a release of DNN Skins and DNN Power Login module version 1.00.03
Power Login is a free dnn module that replaces standard dotnetnuke login module with custom authentication and CSS based layout. As opposed to standard dnn login Power Login by Coding Staff provides web designers with skinning flexibility. Please don't hesitate to discuss this module via DotNetNuke Forum, Snowcovered or directly contact Coding Staff.
Coding Staff - cutting edge dotnetnuke module development and dotnetnuke skinning.
Forums > Users Lounge > Announcements > FREE DNN Power Login module
RE: Server Error in '/' Application. by michellb
Here is the entire text on the page: Server Error in '/' Application. Runtime Error Descrip...
No, I still don't have a solution for this
DNN Creative Subscribe
