Subject: DNN Video Player module
codingstaff
28 Oct 2009 4:30 AM
Coding Staff is proud to announce a release of DotNetNuke Video player module version 2.00.
Coding Staff DotNetNuke video player is the easy solution to add a video to your dnn portal. This player allows you to simply select a video file in module settings, set the size of it and play right from your dnn website. You are not limited to the size of the video you want to be played as long as you can upload it to your server.
We will be happy to hear any recommendations and ideas for improvements of this product. Please don't hesitate to discuss this module via DotNetNuke Forum, Snowcovered or directly contact Coding Staff. To convert a video to flv you can use our Free FLV Converter
Coding Staff - cutting edge dotnetnuke module development and dotnetnuke skinning.
Anthony
17 Mar 2010 2:32 PM
great module. I had trouble playing an .mp4 movie. After purchasing and installing the DNN Video Player from Coding Staff my problems were solved Very reasonable price also Anthony www.webmove.be
Forums > Users Lounge > Announcements > DNN Video Player module
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
