Subject:  DotNetNuke 4.0.0 Starter Kit and Templates...
16 Nov 2005 8:52 AM
A fantastic series of articles have been posted in the asp.net forums by Shaun Walker:
This covers working with DotNetNuke 4.0 and is well worth a read.
Forums > Users Lounge > Announcements > DotNetNuke 4.0.0 Starter Kit and Templates...
Glad you sorted it, thanks,
