Subject: Alive Media Player for DotNetNuke
Yare.Considero
01 Jul 2007 4:01 PM
Considero Alive Media Player is 5-in-1 multimedia player module for DotNetNuke portal platform.
What can it play?
  • FLV Flash video files
  • MP3 music files
  • JPG, GIF, PNG and other image files
  • SWF Flash files
  • iTunes, RSS 2.0, ATOM, XSPF podcast playlists
  • Custom XML playlists
What are supported media sources?
  • It can play files from your DNN server (set folder, single file or playlist to play)
  • Play podcasts, files or custom playlists from other web servers worldwide
 What are the module features?
  • One click to turn your DNN into multimedia audio/video portal. This is standard DotNetNuke module, easy to install, easy to use. All you need is to add module to your portal and set the player mode and media source through the module settings.
  • It uses JavaScript to avoid "Click to activate this user control" message in Internet Explorer
  • Module is localizable through standard DNN localization
  • Automatic playlist generation. Just select the folder with media files and it will generate playlist on-the-fly!
  • Set the preview image or album cover for MP3 or FLV file
  • You can customize width, hight and colors of the player
  • Set the dimensions, position and behaviour of the playlist
  • Player supports watermark logo image
  • If you play MP3 music files, you can enable the graphical equalizer
  • Fullscreen mode for images and FLV Flash video
  • Enable/disable file download
  • Set buffer lenght in seconds. Useful for large files and podcast streaming.
  • And the classic player features like volume, autostart, repeat, shuffle...
dnncovered1
05 Jul 2007 4:15 AM
hi,
you can see Module at our DNNCovered designed site sobertalkradio.com
DNNCovered.com
Web Marketing Consultant
DNN Covered is a one stop solution for buying and selling skins, modules and portals based on DNN (Dotnetnuke) framework.
sales@dnncovered.com | Memberships | Free DNN Stuffs | Contact Us
markp
06 Aug 2007 11:43 AM
Hope your giving Lee a cut of any sales generated by this post.
06 Aug 2007 7:58 PM
Just to make sure that everyone understands ...
This is the "Announcements" forum, so posts like this one are permitted.
Forums > Users Lounge > Announcements > Alive Media Player for DotNetNuke
