Subject: Lost Voice
13 Mar 2007 5:52 AM
Hello all,
I have a slight problem with creating the videos for the next issue 20, I've just lost my voice! So, I propose that I release issue 20 on 1st May instead of 1st April and I will extend all current subscriptions and anyone who subscribes between now and April 1st for a month.
So you will all receive a month extension on your subscription.
Does this sound reasonable?
Let me know what you think, and if a few of you say yes then I will send an e-mail to all subscribers.
Lee
Josd
20 Mar 2007 6:36 AM
Sounds reasonable. What would a video tutorial be without a voice.
Get well soon
Jos
markp
03 Apr 2007 3:49 PM
Ok No problem here, hope the voice issue isnt messing with your holiday.
10 Apr 2007 3:19 AM
Just wanted to say thanks to everyone for their get well comments - I'm now back from my hols feeling refreshed and in full voice!
Lee
