Subject: DNN Creative Updated
09 Feb 2007 3:30 AM
We have just completed a major upgrade to the DNN creative website. This involved changing SQL servers, upgrading the DotNetNuke installation, removing any unused modules and upgrading all the modules to the latest versions.
This upgrade has fixed quite a few problems in the admin section of the website and you should notice that the site is now running much quicker.
If you notice anything unusual on the website please let us know so that we can fix any problems.
The next step for DNN creative is to create a new pure CSS skin...
Forums > Users Lounge > Announcements > DNN Creative Updated
Skim Question by tlsadler
