Subject: DotNetNuke 4.3.7 and 3.3.7 now available
01 Dec 2006 8:36 AM
Another version of DotNetNuke has been released! - I have not come across any information regarding what this update covers, but if you are still on v 4.3.5 I would suggest you upgrade as there was security upgrades in 4.3.6 and there may well be further security upgrades in 4.3.7.
Have fun!
Forums > Users Lounge > Announcements > DotNetNuke 4.3.7 and 3.3.7 now available
ok great, glad to help,
