Subject: FREE Menu Box
codingstaff
10 Dec 2009 4:20 AM
Coding Staff is proud to announce a release of FREE Menu Box version 1.00.04
Coding Staff presents absolutely free DotNetNuke® Navigation platform based on W3C standards and years of skinning challenge that we all had with standard dnn menu provider. There are two new words in dotnetnuke skinning and portal development - Menu Box and Menu Factory.
Menu Box is a menu module for DotNetNuke® CMS that could hold multiple design themes. Each Menu Theme could be applied to Menu Box creating a menu or site map out of it. Menu Box is being shipped with few standard menu themes for clean, CSS based and SEO friendly DotNetNuke Menu and dnn sitemap.
Menu Factory is an online service that you can use to create custom menu themes and apply to Menu Box. Of course, you can design and code custom themes; however, you don't have to if you don't want to - leave it up to Menu Factory.
We will be happy to hear any recommendations and ideas for improvements of this product. Please don't hesitate to discuss this module via DotNetNuke Forum, Snowcovered or directly contact Coding Staff.
Coding Staff - cutting edge dotnetnuke module development and dotnetnuke skinning.
Forums > Users Lounge > Announcements > FREE Menu Box
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
