Subject: DotNetNuke 4.3.6 and 3.3.6 now available
17 Nov 2006 8:03 AM
DotNetNuke 4.3.6 and 3.3.6 now available for download. They contain numerous bug fixes and enhancements, one in particular is a high security risk, as blogged about by Cathal Connolly:
"The newly released 3.3.6/4.3.6 versions, contain a number of security fixes. These were brought to our attention by David Kirby & Christiaan Mellars of Risborrow Information Systems Ltd. One of the bulletins discusses an issue rated as critical and the other discusses two problems fixed as part of a low impact issue.  To fix these issues you are recommended to update to either 3.3.6 or 4.3.6.
You can read more details about these issues and our security policy here"
We therefore strongly recommend that you upgrade to the latest version of DotNetNuke if you are using 4.3.x or 3.3.x. - As always remember to backup everything before attempting an upgrade!
Forums > Users Lounge > Announcements > DotNetNuke 4.3.6 and 3.3.6 now available
