Subject: Repository Core Project Module Released
20 Dec 2005 2:26 AM
I am pleased to inform you that the core project Repository module has just been released!
I'm a member of the project team for the Repository module and it is great to see that Steve Fabian and the rest of the teams hard work has paid off.
You can download the module here:
http://www.dotnetnuke.com/Default.aspx?tabid=831
Other Core project modules that are available are:
Blog module: http://www.dotnetnuke.com/Default.aspx?tabid=854
Forum module: http://www.dotnetnuke.com/Default.aspx?tabid=823
Gallery module: http://www.dotnetnuke.com/Default.aspx?tabid=861
You can see a list of all the core project modules here:
http://www.dotnetnuke.com/tabid/125/default.aspx
Forums > Users Lounge > Announcements > Repository Core Project Module Released
Skim Question by tlsadler
