Subject: DotNetNuke 4.3.3 and 3.3.3 Final Release out now!
20 Jul 2006 10:00 AM
Yes that's correct, the final release of the latest DNN versions are now out!
These should be stable versions, but I have not tested them yet.
You can download them from the main DNN site:
http://www.dotnetnuke.com/tabid/125/default.aspx
Forums > Users Lounge > Announcements > DotNetNuke 4.3.3 and 3.3.3 Final Release out now!
