Subject: How to Create a Portal Signup Module with OWS - Issue 51
01 Dec 2009 7:48 AM
Add any comments or questions regarding the How to Create a Portal Signup Module with OWS
tutorial from Issue 51.
Bizcom.it
02 Dec 2009 10:23 AM
Hi Lee, where can I download the 2.1.18 OWS version ?
In www.openwebstudio.com or http://sourceforge.net/projects/r2iopenwebstudi/files/ sites
the latest version is 2.1.17... and if I try to google "openwebstudio 2.1.18" the unique page found is your tutorial page !
Andrew
02 Dec 2009 4:09 PM
I also would like to know where you can download that latest version of OWS?  Can't find it anywhere.
Joshua Hsu
03 Dec 2009 3:42 AM
Same problem here. Paul?
03 Dec 2009 2:26 PM
Version 2.1.17 is the latest version.
Jon Winters
04 Dec 2009 9:53 PM
@Joe - if you watch the video look in the top right of OWS, it says 2.1.18
@Everyone else who wonders where 2.1.18 is: If you go to SourceForge and go to the SCM Repositories you will see that there have been some code additions to various files. One of the files clearly states the addition of "Portal Creation". So, to get the latest version, I believe you will need to:
1. Download the source of latest version (2.1.17)
2. Install an SVN client
3. Connect to the repository and download the latest file additions
4. Recompile OWS
I think that would get you where you needed to be. However, it is strange that Paul has version 2.1.18 in the videos.
Just my 2 cents.
Jon
05 Dec 2009 6:50 PM
Bizcom.it
06 Dec 2009 2:24 AM
Ok thanks !
Where can I found a documentation of other 'dotnetnuke actions' (if exists) as 'user creation', 'page creation' , etc. ?
06 Dec 2009 9:19 AM
Do you want to do that programmatically?  If so, it's really not documented very well, but that seems to be a current priority for the "core team" so I would expect to see more in the coming months.
In the meantime, the best way to figure this out is to look through the code, ask questions, etc.  There is a "class browser" at http://classbrowser.subzero-solutions.net/home.aspx.
Starting with version 5.2, Intellisense support is available.
Paul Deschenes
10 Dec 2009 5:13 AM
OK, all. I was using a prerelease version of 2.1.18 to describe this new feature which I was told was to have been released BEFORE this video was published.
Unfortunately, there was some hold up on R2Integrated's part. Apparently now I have been assured the 2.1.18 release will be available by 12/14/2009. It may be released before this date so check the www.openwebstudio.com web site download page for updates.
Paul Deschenes
DNN Creative OWS Tutor
Forums > Users Lounge > DNN Creative Articles > How to Create a Portal Signup Module with OWS - Issue 51
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
