Subject: How to Package a Skin for DotNetNuke 5 - issue 49
21 Sep 2009 6:05 AM
Add any comments or questions regarding the How to Package a Skin for DotNetNuke 5 tutorial from Issue no 49
Allen Foster
03 Jan 2010 10:32 AM
How and where would I include psd files for packaging with the skin, with intention of selling?
Thank you.
03 Jan 2010 10:38 AM
The psd file(s) and possibly other files presumably are not needed for installation, but are "support" files that someone might use to modify the skin.
I would create a zip file that includes the installable zip file together with any other files that you want to distribute.  Instruct the users to unzip this file to get the installable zip file.  Some modules that I have acquired have, for example, versions of the module for DotNetNuke versions 4.x and 5.x.  They are zipped into a single file called something like MyModule-UnzipMeFirst.zip.
adski
20 Feb 2010 6:28 AM
You can also use my
Dotnetnuke 5+ Skin Package Manifest Creator
Forums > Users Lounge > DNN Creative Articles > How to Package a Skin for DotNetNuke 5 - issue 49
I did this several years ago, so I think that what I found must have been in the "Professional DotNe...
RE: Server Error in '/' Application. by michellb
Here is the entire text on the page: Server Error in '/' Application. Runtime Error Descrip...
