Subject: SWF Tutorial Conversion
Ray
03 Jul 2009 7:30 AM
I have been trying to convert some of the older SWF tutorials to a format that I can load on my Zune or iPod. I tried several SWF conversion applications without success. When I perform the conversion, the only section that gets converted is the opening and not the body. So far, I tried about 6-7 applications all with the same outcome. Can you offer any suggestions?
Ray
chiconey
06 Jul 2009 8:18 PM
you can convert swf to wmv format for your zune and convert swf to mp4 or h.264 for your ipod.
there are many swf to video converters can do that, but maybe you really got a bad luck.
you can just follow my choice, i use iwisoft swf to wmv converter which can convert swf to h.264 as well. good luck!
Forums > Users Lounge > DNN Creative Articles > SWF Tutorial Conversion
RE: How to Create an Email Form with OWS - Issue 49 by CelesteT
Hi, Was also wondering if there was a way to incorporate ReCaptcha (www.recaptcha.net) into the emai...
Hi, Thanks for the great tutorial. I was wondering how I can hard code a "to" email address into th...
That will work.
DNN Creative Subscribe
