Subject: SWF Tutorial Conversion
Ray
03 Jul 2009 7:30 AM
I have been trying to convert some of the older SWF tutorials to a format that I can load on my Zune or iPod. I tried several SWF conversion applications without success. When I perform the conversion, the only section that gets converted is the opening and not the body. So far, I tried about 6-7 applications all with the same outcome. Can you offer any suggestions?
Ray
03 Jul 2009 12:28 PM
not sure, its not something I have tried, the swf should convert, perhaps its worth googling around for some tips. Let us know if you find a solution as others may find this useful,
Ray
03 Jul 2009 1:05 PM
Thanks and I will continue to research. Each of the applications pick up the introduction (~ 20-25 seconds) and that's it. I also verified that it was not a limitation of the demo software by using a registered version. I think that it has to do something with it being an older version of Flash (???).
Ray
Forums > Users Lounge > DNN Creative Articles > SWF Tutorial Conversion
That will work.
DNN Creative Subscribe
