| RE: localhost Install issues by leesykes |
| If you go to the subscribe page and click on the get free trial button - this takes you to a page wh... |
| localhost Install issues by cdees |
| I've set up a local host and want to run DNN for a local development machine. The host is set up; h... |
| RE: Reversing Limited Access to the Admin Menu by wynnjon |
| That is what I thought. So for my clients that will need to manage user accounts, I can not limit t... |
| RE: Reversing Limited Access to the Admin Menu by leesykes |
| I seem to recall it doesn't work |
| Thanks Lee- I will give that a try.An additional question- If you place the "User Accounts" page un... |
| all you need to do is reverse the process within the SQL tables.Compare the data to the other rows i... |
| RE: Module not working when logged off. by leesykes |
| thanks for the info, |
| Hi! I followed the tutorial for limiting the access to the admin menu. What a great thing!However,... |
| RE: Trouble installing! Designer trying to be a Developer. by leesykes |
| glad to hear you found a solution, thanks, |
| RE: Skim Question by leesykes |
| You could but you will not be able to have an XHTML compliant page as the SolpartMenu is non-complia... |
| RE: Include in Menu - Weird Request by leesykes |
| For your sitemap.xml file - use GSiteCrawlerYou could create the site map before moving the sub menu... |
| RE: Trouble installing! Designer trying to be a Developer. by awright14 |
| It looks like I had ASP installed in the wrong order. Copying and pasting this into the Run Command... |
| RE: Need Help Changing Containers Contentpane's Text Color by leesykes |
| Hello,Have you tried adding a class to the content area of your container and then styling the p, a,... |
| RE: Vertical SolpartMenu by leesykes |
| hello,If you wish to display the admin and host menus within the house menu, you need to enable it i... |
| RE: Firefox Does Not Display WMV File In Media Module by leesykes |
| Hello,I have just tested this and I can play a wmv file in Firefox 3.0.3, so it does suggest that it... |
| RE: advice wanted convert site to DNN while keeping existing asp functionality by leesykes |
| You could try using the IFrame module in DotNetNuke and then just link the IFrame to the current pag... |
| RE: Need Help Changing Containers Contentpane's Text Color by CROKeefe |
| Thanks for the quick update... I know it looks broken right now, but I had the TITLE classes working... |
| The default class for a container is .head so you will find that the .head class will override any s... |
| RE: Module not working when logged off. by t.ramya85 |
| have to set the cache time to '0' in that module setting. |
| Hi Everyone,Just to let you know, I'm very new at this - very new to any type of dev environments in... |
