Subject: CAPTCHA not working
17 Dec 2007 4:10 AM
Lee,
I was configuring CAPTCHA settings on a DNN site I am developing and have run into a problem. After enabling the CAPTCHA settings as explained in the video tutorial User Accounts Settings in Issue 13 of DNN Creative my site does not show the CAPTCHA image control, see screenshot attached. I have disabled registration for this site, would that affect the CAPTCHA settings? It would be great if you could point me in the right direction. DNN version is 04.07.00
Thanks Jav
I have just tested this in version 4.7 and I have the same problem.  If I enable registration, the registration page will display the capture image, but the login page will not display the capture image. This looks as though it could be a new bug in version 4.7. I would suggest you contact DotNetNuke.com and see if they have identified this as a bug.
PS. - if you have any questions in the future, please ask them in the forum as you will get a much quicker response and everyone else can then learn from the answers.
javeedg
17 Dec 2007 4:23 AM
Thanks Lee for the quick reply.
I will post this as a bug to DotNetNuke and keep you posted on that.
vodaley
07 Jun 2008 7:25 AM
same problem happend here, I'm using DNN 4.08.01
vodaley
07 Jun 2008 7:31 AM
AssemblyVersion: 04.08.01
PortalID: -1
PortalName:
UserID: -1
UserName:
ActiveTabID: -1
ActiveTabName:
RawURL: /DesktopModules/AuthenticationServices/DNN/ImageChallenge.captcha.aspx?captcha=1986A74F9CD1CACF78EB9E76BC740C4505B55217CA7AF56BBB649C5FDF31B60576DE7639CD2CBCD74731DB2BD4083FA27F69031D6DC1556605748D8C1DC9E25975FA18A98BD55CCCFC589281CF5280D610CC924307FF4ADEA50F39E1AE98F5DD10AA40651C71B809615DDAE19073452CB5EC1F4C9B6B807BCFF17B2C507217E4&alias=www.fs-commercial.net
AbsoluteURL: /DesktopModules/AuthenticationServices/DNN/ImageChallenge.captcha.aspx
AbsoluteURLReferrer: http://www.fs-commercial.net/
UserAgent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.0.04506; .NET CLR 3.5.21022)
ExceptionGUID: 5aea5d29-5e41-4c41-bf0e-3b1e8a827ced
InnerException: Input string was not in a correct format.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: System.Number.StringToNumber
StackTrace:
Message: System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at DotNetNuke.UI.WebControls.CaptchaControl.GenerateImage(String encryptedText)
Source:
Server Name: DED622
Forums > Users Lounge > DNN Creative Articles > CAPTCHA not working
